Ga door naar hoofdinhoud
Inleiding
This is a prerequisite only guide. It disconnects most of the connectors and removes most of the screws to take the motherboard out. The shots are taken such that you can’t see whether the Taptic Engine is out or not.
Note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
Opening the iPhone 8 will damage the waterproof seals on the display. If you do not replace the adhesive seals, your phone will function normally, but will no longer be water-resistant.
  1. Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket. Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
    • Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
  2. Remove the two screws securing the rear-facing camera bracket:
    • Remove the two screws securing the rear-facing camera bracket:
    • One 3.0 mm standoff screw
    • One 3.1 mm Phillips screw
    • Standoff screws are best removed using a standoff screwdriver or bit.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
  3. Remove the rear-facing camera bracket.
    • Remove the rear-facing camera bracket.
  4. Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up. Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
    • Use the point of a spudger to disconnect the flash connector from its socket by prying it straight up.
  5. Remove the two screws securing the upper cable bracket:
    • Remove the two screws securing the upper cable bracket:
    • One 2.9 mm Phillips screw
    • One 1.3 mm Phillips screw
  6. Remove the upper cable bracket.
    • Remove the upper cable bracket.
  7. Use the flat end of a spudger to pry the upper cable connector up from its socket. Use the flat end of a spudger to pry the upper cable connector up from its socket.
    • Use the flat end of a spudger to pry the upper cable connector up from its socket.
  8. Remove the three Phillips 1.3 mm screws securing the top left antenna component.
    • Remove the three Phillips 1.3 mm screws securing the top left antenna component.
  9. Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
    • Remove the 1.4 mm Phillips screw securing the antenna component to the top of edge of the case.
  10. Remove the antenna component.
    • Remove the antenna component.
  11. Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
    • One 1.5 mm Phillips screw
    • One 2.6 mm Phillips screw
  12. Remove the grounding clip.
    • Remove the grounding clip.
  13. Remove the three screws securing the motherboard:
    • Remove the three screws securing the motherboard:
    • One 1.8 mm Phillips screw
    • One 2.5 mm standoff screw
    • One 2.2 mm standoff screw
  14. Use tweezers to gently bend the logic board grounding bracket out of the way. Use tweezers to gently bend the logic board grounding bracket out of the way.
    • Use tweezers to gently bend the logic board grounding bracket out of the way.
  15. Use the point of a spudger to move the SIM card eject plunger out of the logic board's way. Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
    • Use the point of a spudger to move the SIM card eject plunger out of the logic board's way.
Conclusie
Arthur Shi
173.576 Reputatie
428 handleidingen geschreven
iFixit Lid van iFixit
Community
140 Leden
17.052 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 127
