Inleiding
Use this guide to replace the throttle lever and cable in a Little Beaver Augers MDL5HD 2017.
The auger bit is removed in this guide. While not necessary, removing it will make the repair easier.
Wat je nodig hebt
Pull the spark plug connector straight off of the spark plug.
Use a Phillips #2 screwdriver to loosen the screw securing the throttle cable clamp.
Use needle nose pliers to bend the flared end of the rivet inward to straighten it.
Één andere persoon heeft deze handleiding voltooid.
