Inleiding
Use this guide to replace the clutch assembly in a Little Beaver Augers MDL5HD 2017.
The auger bit is removed in this guide. While not necessary, removing it will make the repair easier.
Wat je nodig hebt
Pull the spark plug connector straight off of the spark plug.
Use a 5/16 inch socket to remove the two nuts securing the clutch bracket clamp.
Use a 5/32 inch hex wrench to loosen the two set screws on the clutch drum.
Use a long-handle 5/32 inch hex wrench to loosen the two set screws on the clutch rotor assembly.
