Ga door naar hoofdinhoud
Lite-On iHAS324 Disc Tray Belt Replacement
Wat je nodig hebt
  1. Lite-On iHAS324 Disc Tray Belt Replacement, Chassis: stap 1, afbeelding 1 van 2 Lite-On iHAS324 Disc Tray Belt Replacement, Chassis: stap 1, afbeelding 2 van 2
    • Insert a paper clip into a small hole on the right side of the faceplate bellow the disc tray.
    • There may be resistance, do not be afraid to use force.
    • The tray should then pop open.
    • Pull out the tray so that it is fully extended.
  2. Lite-On iHAS324 Disc Tray Belt Replacement: stap 2, afbeelding 1 van 3 Lite-On iHAS324 Disc Tray Belt Replacement: stap 2, afbeelding 2 van 3 Lite-On iHAS324 Disc Tray Belt Replacement: stap 2, afbeelding 3 van 3
    • Use a plastic opening tool to push the three tabs located on the right, left, and bottom side of the outer chassis to loosen the faceplate off.
  3. Lite-On iHAS324 Disc Tray Belt Replacement: stap 3, afbeelding 1 van 1
    • Pull the faceplate off the chassis.
    • Do NOT pull the faceplate all the way off the disc tray, because doing so can cause damage to the faceplate.
  4. Lite-On iHAS324 Disc Tray Belt Replacement: stap 4, afbeelding 1 van 1
    • Using the Phillips Head #2 screwdriver, unscrew the two 8.5 mm screws located on the bottom back of the chassis.
  5. Lite-On iHAS324 Disc Tray Belt Replacement: stap 5, afbeelding 1 van 1
    • Remove the bottom plate by lifting it off the device.
  6. Lite-On iHAS324 Disc Tray Belt Replacement: stap 6, afbeelding 1 van 1
    • Turn the device over.
    • Remove the top plate by pulling the sides and lifting the plate off.
  7. Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray: stap 7, afbeelding 1 van 2 Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray: stap 7, afbeelding 2 van 2
    • Push the left tab in and slide the tray out on the left side.
    • Pull the gray plastic casing on the right side away from the tray.
    • Slide the right side of the tray out.
  8. Lite-On iHAS324 Disc Tray Belt Replacement, Disc Tray Belt: stap 8, afbeelding 1 van 1
    • Take tweezers and remove the black tray belt from the gears carefully.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Kayla Culpepper
675 Reputatie
5 handleidingen geschreven
Baylor, Team 5-9, Williams Spring 2015 Lid van Baylor, Team 5-9, Williams Spring 2015
BU-WILLIAMS-S15S5G9
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 48
Altijd: 1,437
