Ga door naar hoofdinhoud
Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement
Wat je nodig hebt
  1. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Back Panel Removal: stap 1, afbeelding 1 van 1
    • Turn the device over so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: stap 2, afbeelding 1 van 1
    • Peel off the piece of metal that is glued to hold the two halves of the base together.
    • You may need rubber cement to reapply the piece of metal when reassembling the device.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: stap 3, afbeelding 1 van 2 Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the four 10mm Phillips head screws on the bottom of the device.
    • Once the base is removed, the device should look as shown on the picture.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement, Motor: stap 4, afbeelding 1 van 2 Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement, Motor: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers to crush the sides of the wirenuts.
    • The wirenuts are crimped to lock the wires in place. Usually the wires are just twisted into them.
    • Pull all of the wires out of the wirenuts.
  5. Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: stap 5, afbeelding 1 van 2 Lite FX Rotating Big Ball of Lite Model 1929 Motor Replacement: stap 5, afbeelding 2 van 2
    • Separate the wires that belong to the motor.
    • The wires should be small and black.
    • Remove the motor.
Conclusie
To reassemble your device, follow these instructions in reverse order, starting from step five.
Courtney Elliott
375 Reputatie
3 handleidingen geschreven
Cal Poly, Team 17-3, Forte Winter 2014 Lid van Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Leden
7 handleidingen geschreven
2 opmerkingen
Where can you find a replacement motor?
bellyjb - Antwoord
I can't find one either!!!!
Dallin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 2,733
