Ga door naar hoofdinhoud
Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement
Wat je nodig hebt
  1. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: stap 1, afbeelding 1 van 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: stap 2, afbeelding 1 van 3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: stap 2, afbeelding 2 van 3 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: stap 2, afbeelding 3 van 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement: stap 3, afbeelding 1 van 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: stap 4, afbeelding 1 van 2 Lite FX Rotating Big Ball of Lite Model 1929 Light Bulb Replacement, Light Bulb: stap 4, afbeelding 2 van 2
    • Unscrew the burnt-out light bulb with a counter-clockwise twist.
    • Do not apply too much pressure when unscrewing light bulb, as the light bulb may break.
Eindstreep
5 andere personen hebben deze handleiding voltooid.
Nick Kaprielian
525 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-3, Forte Winter 2014 Lid van Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Leden
7 handleidingen geschreven
4 opmerkingen
Great! Wasn't sure how to remove the base. Thank you!
derigo1957 - Antwoord
Saved me a headache. Couldn't figure out how to remove base. Thanks!
mccullough1251 - Antwoord
Helpful guide. Thank you.
In case there is any confusion, all you have to do is push in that tab on one side and lift. No twisting necessary. Also, the other side will come off.
jgprus - Antwoord
Thank you so much! I was afraid of breaking the globe. That really helped because I couldn’t figure out how to disconnect the base.
Melissa Fleming - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 19
Afgelopen 30 dagen: 84
Altijd: 15,459
