Ga door naar hoofdinhoud
Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement
Wat je nodig hebt
  1. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Lite FX Rotating Big Ball of Lite Model 1929 Ball Disassembly: stap 1, afbeelding 1 van 1
    • Unplug the device to avoid injury.
    • Turn the device over, so that the base is on top.
  2. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: stap 2, afbeelding 1 van 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: stap 2, afbeelding 2 van 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: stap 2, afbeelding 3 van 3
    • Compress the tab by pushing towards the center of the device with a spudger.
    • While compressing the tab, peel the base away from the rotating head.
  3. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement: stap 3, afbeelding 1 van 1
    • If the metal brackets come off of the sphere, put them back on the plastic piece as shown in the photo.
  4. Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: stap 4, afbeelding 1 van 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: stap 4, afbeelding 2 van 3 Lite FX Rotating Big Ball of Lite Model 1929 Color Panel Replacement, Color Panel: stap 4, afbeelding 3 van 3
    • Push the color panel by applying pressure from the inside while twisting to line up the tabs with the notches.
    • Insert a new color panel by pushing it into place while lining up the tabs with the notches.
Conclusie
Nick Kaprielian
525 Reputatie
4 handleidingen geschreven
Cal Poly, Team 17-3, Forte Winter 2014 Lid van Cal Poly, Team 17-3, Forte Winter 2014
CPSU-FORTE-W14S17G3
5 Leden
7 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 16
Altijd: 652
