Ga door naar hoofdinhoud
Linsay Model F-7HD2CORE Battery Replacement
Wat je nodig hebt
  1. Linsay Model F-7HD2CORE Battery Replacement, Battery: stap 1, afbeelding 1 van 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: stap 1, afbeelding 2 van 3 Linsay Model F-7HD2CORE Battery Replacement, Battery: stap 1, afbeelding 3 van 3
    • Carefully insert your plastic opening tool in between the white and black sections of your device.
    • Gently pry the top screen portion from the base of the tablet.
    • Your tablet should now look like the third image.
  2. Linsay Model F-7HD2CORE Battery Replacement: stap 2, afbeelding 1 van 2 Linsay Model F-7HD2CORE Battery Replacement: stap 2, afbeelding 2 van 2
    • To completely remove the base from the top of the tablet, peel the microphone from the back.
  3. Linsay Model F-7HD2CORE Battery Replacement: stap 3, afbeelding 1 van 2 Linsay Model F-7HD2CORE Battery Replacement: stap 3, afbeelding 2 van 2
    • Remove the two pieces of tape holding the battery in place by gently peeling it off.
  4. Linsay Model F-7HD2CORE Battery Replacement: stap 4, afbeelding 1 van 1
    • Using the spudger, carefully peel the battery off of the tablet panel.
    • Tape of the back of the battery will be very strong, pull gently!
    • The metal exterior of the battery can be quite pliable. Use caution when removing the battery from the tablet.
  5. Linsay Model F-7HD2CORE Battery Replacement: stap 5, afbeelding 1 van 1
    • To remove the battery, completely desolder the wires connected to the circuit board.
    • To reattach the new battery, you must solder the wires back on.
Conclusie
Lindsay Byrnes
471 Reputatie
2 handleidingen geschreven
Penn State, Team 1-5, Kaschak Winter 2015 Lid van Penn State, Team 1-5, Kaschak Winter 2015
PSU-KASCHAK-W15S1G5
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 1,436
