Inleiding
In this guide you will remove the router's front case and begin to have access to the router's internal components.
  1. Turn the router over so that all four of its feet are facing upwards.
    • Turn the router over so that all four of its feet are facing upwards.
  2. Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • Remove the rubber inserts inside the the two purple feet located on the router's front case.
    • This may be a challenge, so try the following two methods:
    • Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
    • Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
    • Use a Phillips #2 Screwdriver to remove the two 5.8 mm screws holding the front case to the motherboard.
  5. Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
    • Squeeze the sides of the router's backcase inward and pull off the purple front case. It is helpful to have a second person assist you for this step.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Allian Roman
276 Reputatie
5 handleidingen geschreven
Cal Poly, Team 3-4, Regan Fall 2011 Lid van Cal Poly, Team 3-4, Regan Fall 2011
CPSU-REGAN-F11S3G4
4 Leden
6 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 2
Altijd: 895
