Ga door naar hoofdinhoud
Linksys WRT54G Antennas Replacement
Wat je nodig hebt
  1. Linksys WRT54G Antennas Replacement, Antennas: stap 1, afbeelding 1 van 1
    • Unfold the antennas straight away from the device.
  2. Linksys WRT54G Antennas Replacement: stap 2, afbeelding 1 van 3 Linksys WRT54G Antennas Replacement: stap 2, afbeelding 2 van 3 Linksys WRT54G Antennas Replacement: stap 2, afbeelding 3 van 3
    • Remove the black caps from the antennas by pulling them away from the device.
  3. Linksys WRT54G Antennas Replacement: stap 3, afbeelding 1 van 3 Linksys WRT54G Antennas Replacement: stap 3, afbeelding 2 van 3 Linksys WRT54G Antennas Replacement: stap 3, afbeelding 3 van 3
    • Unscrew each of the antennas from the wireless device.
  4. Linksys WRT54G Antennas Replacement, Antennas: stap 4, afbeelding 1 van 2 Linksys WRT54G Antennas Replacement, Antennas: stap 4, afbeelding 2 van 2
    • Once the old antennas are removed, replace them with them with the new ones by screwing them on the device.
Conclusie
Aaron Brown
163 Reputatie
2 handleidingen geschreven
Cal Poly, Team 17-7, Regan Fall 2011 Lid van Cal Poly, Team 17-7, Regan Fall 2011
CPSU-REGAN-F11S17G7
4 Leden
4 handleidingen geschreven
2 opmerkingen
I have a wrt54gs and the antennas are plastic crap with no cuff to unscrew. They are fastened in by "body snaps" like most of the cheap crap that's made in china. Off to find instructions for router disassembly. Just thought you should know this won't necessarily work for the models listed.
Ed Rutmayer - Antwoord
Most do not have removeable antennaes
tom - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 5,750
