Ga door naar hoofdinhoud
Linksys WAP54g LED Lights Replacement
Wat je nodig hebt
  1. Linksys WAP54g LED Lights Replacement, Top Casing: stap 1, afbeelding 1 van 1
    • Power down and unplug the device.
  2. Linksys WAP54g LED Lights Replacement: stap 2, afbeelding 1 van 1
  3. Linksys WAP54g LED Lights Replacement: stap 3, afbeelding 1 van 1
    • Remove the two black rubber feet of the device using the screwdriver. The feet are located on the bottom towards the front.
  4. Linksys WAP54g LED Lights Replacement: stap 4, afbeelding 1 van 1
    • Once the feet are removed, two small screws will be visible. With a small screwdriver, unscrew them. Screws are phillips head, 4.35 mm in diameter, 7.88 mm in length.
  5. Linksys WAP54g LED Lights Replacement: stap 5, afbeelding 1 van 1
    • To remove the front blue panel, grip firmly and place thumbs in the two notches on top. Push thumbs forward while keeping a firm grip on bottom.
    • This may require a bit of force.
  6. Linksys WAP54g LED Lights Replacement: stap 6, afbeelding 1 van 1
    • Now slide the bottom panel forward and remove it so the top casing is isolated from the bottom casing and motherboard.
  7. Linksys WAP54g LED Lights Replacement: stap 7, afbeelding 1 van 2 Linksys WAP54g LED Lights Replacement: stap 7, afbeelding 2 van 2
    • Unscrew the nut on the outer side of the back casing. Remove the nut and the washer from both antenna mounts.
  8. Linksys WAP54g LED Lights Replacement: stap 8, afbeelding 1 van 2 Linksys WAP54g LED Lights Replacement: stap 8, afbeelding 2 van 2
    • From here, remove the wires and nuts connected to the back panel by pulling the nuts through the holes.
    • Now the top casing has been removed and isolated from the rest of the device. From here, you can make repairs to the top casing.
    • Once the top panel is removed the main board will still be attached to the bottom panel.
  9. Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: stap 9, afbeelding 1 van 2 Linksys WAP54g LED Lights Replacement, Bottom Casing/Motherboard: stap 9, afbeelding 2 van 2
    • Unscrew the two screws that connect the motherboard to the bottom casing.
    • The motherboard and bottom casing should be completely separated at this point. This allows for replacement of the motherboard and/ or its components as well as the bottom casing.
  10. Linksys WAP54g LED Lights Replacement, LED Lights: stap 10, afbeelding 1 van 1
    • Using a soldering iron, desolder the LED lights from the bottom of the logic board.
    • For help with soldering or desoldering refer to ifixit's soldering guide: Hoe moet je (de-)solderen?
  11. Linksys WAP54g LED Lights Replacement: stap 11, afbeelding 1 van 1
    • Place new LED lights through holes created by desoldering and removing old lights.
  12. Linksys WAP54g LED Lights Replacement: stap 12, afbeelding 1 van 2 Linksys WAP54g LED Lights Replacement: stap 12, afbeelding 2 van 2
    • Solder the lights onto the bottom of the board to solidify the connection and make electrical contact.
    • Follow the Installing the Casing guide in reverse to re-assemble your device.
Conclusie
Once the soldering is complete, the device should work and the LED lights should light up.
Één andere persoon heeft deze handleiding voltooid.
Derek Myers
288 Reputatie
5 handleidingen geschreven
Cal Poly, Team 21-21, Maness Fall 2011 Lid van Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,046
