Ga door naar hoofdinhoud
Linksys WAP54g Casing Replacement
Wat je nodig hebt
  1. Linksys WAP54g Casing Replacement, Casing: stap 1, afbeelding 1 van 1
    • Power down and unplug the device.
  2. Linksys WAP54g Casing Replacement: stap 2, afbeelding 1 van 1
    • Start by removing the two black rubber stoppers that act as the cushions to the legs of the device. The stoppers are located on the bottom towards the front of the device.
  3. Linksys WAP54g Casing Replacement: stap 3, afbeelding 1 van 1
    • Once removed two small screws will be visible. With a small screwdriver unscrew the screws.
  4. Linksys WAP54g Casing Replacement: stap 4, afbeelding 1 van 1
    • Remove the blue front panel from the rest of the device. You can now see the main board.
  5. Linksys WAP54g Casing Replacement: stap 5, afbeelding 1 van 1
    • Now slide the bottom panel forward and remove it so the main board is attached to the bottom panel.
  6. Linksys WAP54g Casing Replacement: stap 6, afbeelding 1 van 1
    • From here, remove the wires and nuts connected to the back panel of the casing by pulling the nuts through the holes in the casing.
  7. Linksys WAP54g Casing Replacement: stap 7, afbeelding 1 van 1
    • Once the bottom panel is removed unscrew the screws from the main board to the bottom panel so the main board is independent of the bottom panel.
  8. Linksys WAP54g Casing Replacement: stap 8, afbeelding 1 van 1
    • From here, all of the pieces of the casing are removed and the main board is independent of the entire casing.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Derek Myers
288 Reputatie
5 handleidingen geschreven
Cal Poly, Team 21-21, Maness Fall 2011 Lid van Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,040
