Ga door naar hoofdinhoud
Linksys WAP54g Antennas Replacement
  1. Linksys WAP54g Antennas Replacement, Antennas: stap 1, afbeelding 1 van 2 Linksys WAP54g Antennas Replacement, Antennas: stap 1, afbeelding 2 van 2
    • Make sure the antennas are in a straight position, not bent, to remove the black casing.
    • Remove the casing by pulling straight up. This will make unscrewing the antenna easier.
  2. Linksys WAP54g Antennas Replacement: stap 2, afbeelding 1 van 1
    • Grip antenna at the base and twist counter-clockwise to unscrew it from the device. The base should have a rough feel to it.
  3. Linksys WAP54g Antennas Replacement: stap 3, afbeelding 1 van 1
    • Once antenna is completely detached, obtain the new antenna, and place it on device so the threads line up.
  4. Linksys WAP54g Antennas Replacement: stap 4, afbeelding 1 van 1
    • Screw antenna onto device by twisting the base of the antenna in a clockwise motion until it is tight and does not turn any further.
  5. Linksys WAP54g Antennas Replacement: stap 5, afbeelding 1 van 1
    • Place the black casing, which was removed in step 1, back onto the base of the antenna to cover up exposed metal.
    • Repeat these steps for other antenna.
Conclusie
After the repairs are made the device should working.
Derek Myers
288 Reputatie
5 handleidingen geschreven
Cal Poly, Team 21-21, Maness Fall 2011 Lid van Cal Poly, Team 21-21, Maness Fall 2011
CPSU-MANESS-F11S21G21
5 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 2,576
