Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Be sure the ethernet and power cables are disconnected from the device.
You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
Use the tweezers to remove the two rubber boots on the front two legs. The easiest way to do this is to insert the tweezers into the hole in the face of the boot. Once you are hooked behind the boot, pull outwards.
This will reveal two small Phillips-head screws. Remove them.
Using two hands (one on the front of the device and the other on the back) apply pressure to the top and bottom seal while pulling the front and back away from each other.
The seal is located where the blue plastic meets the black plastic. This is where you will apply pressure.
After the face of the device has been removed, slide the base of the device off to reveal the motherboard and other internal components.
This is what the device looks like when it is fully opened.
Using a Phillips screwdriver remove the the three screws that fasten the main circuit board to the chassis.
Using a pair of needle nose pliers, remove the nuts that secure the antenna ports to the rear panel.
Using a soldering iron and desoldering wick, desolder and remove the two antennas from the motherboard.
The antenna can now be replaced with a new one.
