Inleiding
Sending and receiving wireless signals requires an antenna. If the antenna is faulty, the device will not work as intended. Replacing the antenna should resolve most connectivity issues.
Wat je nodig hebt
Be sure the ethernet and power cables are disconnected from the device.
You should also unscrew the external plastic antennas. There is one antenna on each side of the device.
Using a Phillips screwdriver remove the the three screws that fasten the main circuit board to the chassis.
