Onderdelen
Geen onderdelen opgegeven.
  1. Remove the sticker on the bottom. Remove the two screws holding the bottom plate in place.  Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
    • Remove the sticker on the bottom.
    • Remove the two screws holding the bottom plate in place. Use Phillips screwdriver tip #1 , the screw head-size is 5mm.
  2. Remove the back sticker that has all the labels. There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
    • Remove the back sticker that has all the labels.
    • There are two screws to remove. They are 6mm in diameter, use phillips screw tip #1.
  3. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
  4. Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage. Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage. Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
    • Depress the 12 clips along the edge into the router. Use the nylon spudger as using a metal object could cause damage.
  5. Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together. These clips are tough and may need some additional force. These clips are tough and may need some additional force.
    • Once you have one side open, keep a spudger wedged between both sides. This will help keep it open in case it tries to snap back together.
    • These clips are tough and may need some additional force.
  6. Lift the board and pull down, away from the antennas. Lift the board and pull down, away from the antennas. Lift the board and pull down, away from the antennas.
    • Lift the board and pull down, away from the antennas.
Conclusie
Henry Cates
165 Reputatie
1 Handleiding geschreven
USF Tampa, Team 9-1, Lacy Fall 2016 Lid van USF Tampa, Team 9-1, Lacy Fall 2016
USFT-LACY-F16S9G1
4 Leden
5 handleidingen geschreven
Voeg een opmerking toe
Bekijk statistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 21
Aller tijden: 786
