Ga door naar hoofdinhoud
Linksys EA6900 Power Port Replacement
Wat je nodig hebt
  1. Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: stap 1, afbeelding 1 van 3 Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: stap 1, afbeelding 2 van 3 Linksys EA6900 Power Port Replacement, Linksys EA6900 Disassembly: stap 1, afbeelding 3 van 3
    • Remove the antennas by unscrewing them from the base.
    • Flip over the device and locate the four rubber feet on the bottom.
    • Remove the rubber feet with tweezers
  2. Linksys EA6900 Power Port Replacement: stap 2, afbeelding 1 van 1
    • Remove the 0.4cm head screws from each slot with the #1 Phillips head Screwdriver.
  3. Linksys EA6900 Power Port Replacement: stap 3, afbeelding 1 van 1
    • Use a blue plastic opening tool to remove the top cover.
    • Move the blue plastic opening tool gently underneath the top cover from side to side.
  4. Linksys EA6900 Power Port Replacement: stap 4, afbeelding 1 van 3 Linksys EA6900 Power Port Replacement: stap 4, afbeelding 2 van 3 Linksys EA6900 Power Port Replacement: stap 4, afbeelding 3 van 3
    • Gently lift the motherboard and remove it from the case
    • Put the motherboard over a (preferably white) surface.
  5. Linksys EA6900 Power Port Replacement, Power Port: stap 5, afbeelding 1 van 2 Linksys EA6900 Power Port Replacement, Power Port: stap 5, afbeelding 2 van 2
    • Locate the power port on both sides of the motherboard.
    • The power port on the top side is in a rectangular black casing.
    • Identify the three prongs where the power port is soldered to on the reverse side.
  6. Linksys EA6900 Power Port Replacement: stap 6, afbeelding 1 van 3 Linksys EA6900 Power Port Replacement: stap 6, afbeelding 2 van 3 Linksys EA6900 Power Port Replacement: stap 6, afbeelding 3 van 3
    • Carefully apply the soldering iron on each of the three points on the bottom side of the motherboard to melt them.
    • Be careful to not touch the motherboard with the soldering iron, you can damage the circuits.
    • After you have melted and removed the solder, flip the mother board around and identify the connecting points of the power port.
    • Use a black spudger to gently separate the power port from the motherboard
Conclusie
Tyler Markiewicz
267 Reputatie
1 Handleiding geschreven
USF Tampa, Team 11-1, Blackwell Fall 2016 Lid van USF Tampa, Team 11-1, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G1
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 13
Altijd: 800
