Ga door naar hoofdinhoud
Lightahead DV328 Arrow Button Replacement
Wat je nodig hebt
  1. Lightahead DV328 Arrow Button Replacement, Arrow Button: stap 1, afbeelding 1 van 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: stap 1, afbeelding 2 van 3 Lightahead DV328 Arrow Button Replacement, Arrow Button: stap 1, afbeelding 3 van 3
    • Use a spudger to remove the two screw covers.
    • Remove the two Phillips #0 screws.
  2. Lightahead DV328 Arrow Button Replacement: stap 2, afbeelding 1 van 3 Lightahead DV328 Arrow Button Replacement: stap 2, afbeelding 2 van 3 Lightahead DV328 Arrow Button Replacement: stap 2, afbeelding 3 van 3
    • Once you are able to lift the cover up, you will then be able to pry off the lens which will allow for the device to open more.
    • Take off the lens cover. Be careful not to pull the device open too much otherwise you will snap it in half since it is made of plastic.
    • Once you have this up, pull up the cover and you will now be able to work on the arrow key button
  3. Lightahead DV328 Arrow Button Replacement: stap 3, afbeelding 1 van 3 Lightahead DV328 Arrow Button Replacement: stap 3, afbeelding 2 van 3 Lightahead DV328 Arrow Button Replacement: stap 3, afbeelding 3 van 3
    • Lay the camcorder on its side. The arrow key button is now in full view.
    • There is a small green piece locking in the arrow key button. Once you remove that, the piece will be able to come out.
    • Gently push on the button and it will come out of the device. Replace as needed
Conclusie
Alexandra McMurray
355 Reputatie
3 handleidingen geschreven
USF Tampa, Team 10-2, Remmell Spring 2016 Lid van USF Tampa, Team 10-2, Remmell Spring 2016
USFT-REMMELL-S16S10G2
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 193
