Ga door naar hoofdinhoud
LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming
Wat je nodig hebt
  1. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: stap 1, afbeelding 1 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: stap 1, afbeelding 2 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming, Battery: stap 1, afbeelding 3 van 3
    • Use a spudger to gently pry open the remote case to access the battery compartment.
  2. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 2, afbeelding 1 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 2, afbeelding 2 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 2, afbeelding 3 van 3
    • Carefully remove the old battery using a spudger.
  3. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 3, afbeelding 1 van 2 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 3, afbeelding 2 van 2
    • Place the new battery into the compartment securely, noting the orientation of its positive and negative sides.
  4. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 4, afbeelding 1 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 4, afbeelding 2 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 4, afbeelding 3 van 3
    • Turn the remote upside down and push the cover gently until you hear a click, ensuring it is securely closed.
    • Align the cover to the remote buttons.
  5. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 5, afbeelding 1 van 2 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 5, afbeelding 2 van 2
    • Locate the garage door system on top of the garage and open it.
  6. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 6, afbeelding 1 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 6, afbeelding 2 van 3 LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 6, afbeelding 3 van 3
    • Locate the learn button.
    • Press and release the receiver learn button.
    • Within 30 seconds, press and hold remote button.
    • When the opener light flashes, release the remote button which means the programming was successful.
  7. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 7, afbeelding 1 van 1
    • Press the remote button to ensure it opens and closes the garage door as expected.
    • If the remote does not work, repeat Step 6.
  8. LiftMaster 893LM Garage Remote Battery Replacement and Reprogramming: stap 8, afbeelding 1 van 1
    • In case the remote fails and the garage door is closed, use the side-mounted wall remote for emergency access.
    • Press the green light.
Eindstreep
Luay Ghabayin
157 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 26
Afgelopen 30 dagen: 148
Altijd: 1,457
