Inleiding
This is a guide will show you how to fix a detached leg from a 4-foot adjustable folding table from Lifetime. Whether it's from excessive weight, gradual deterioration, or accidental impacts, the chances of table leg damage increases with use. This tutorial is designed to help people understand what to do if the table legs become detached.
Wat je nodig hebt
Use the 6 mm Flathead screwdriver to remove the four aluminum slotted screws located on the edges of the table.
Use a 5/32" Allen Wrench or 19 mm wrench to remove the two stainless 8-18 steel hex screws from the braces of the table.
