Ga door naar hoofdinhoud
LifePrint 3x4.5 Charging Port Replacement
Wat je nodig hebt
  1. LifePrint 3x4.5 Charging Port Replacement, Top Cover: stap 1, afbeelding 1 van 1
    • Place one hand on the top cover and one hand on the bottom portion of the LifePrint.
    • While having the LP logo on the printer facing away from you, push the top cover away from you until it can't be slid away any further.
    • Pull the cover with the LP logo up to separate it from the rest of the printer.
  2. LifePrint 3x4.5 Charging Port Replacement, Inner Cover: stap 2, afbeelding 1 van 1
    • Using a Phillips #0 screwdriver, remove the four 15 mm screws connecting both sections of the device.
    • Use an opening tool to remove the inner cover from the printer.
  3. LifePrint 3x4.5 Charging Port Replacement, Charging Port: stap 3, afbeelding 1 van 1
    • Remove the five Phillips #0 screws from the outer edge of the motherboard indicated by the copper color surrounding the screws' housing.
  4. LifePrint 3x4.5 Charging Port Replacement: stap 4, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a soldering iron to heat up the soldering joints surrounding the port that connects the device to the circuit board.
    • After the solder is heated up use the de-soldering wick to absorb the solder holding the socket to the circuit board .
    • After the solder is removed use the tweezers to remove the port from the circuit board.
Conclusie
Jacqueline Broderick
341 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team S1-G2, Barthe Fall 2019 Lid van UMass Dartmouth, Team S1-G2, Barthe Fall 2019
UMASSD-BARTHE-F19S1G2
3 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 10
Altijd: 338
