Ga door naar hoofdinhoud
Lezyne CNC Dirt Floor Drive Hose Replacement
Wat je nodig hebt
  1. Lezyne CNC Dirt Floor Drive Hose Replacement, Drive Hose: stap 1, afbeelding 1 van 3 Lezyne CNC Dirt Floor Drive Hose Replacement, Drive Hose: stap 1, afbeelding 2 van 3 Lezyne CNC Dirt Floor Drive Hose Replacement, Drive Hose: stap 1, afbeelding 3 van 3
    • Use a pair of pliers to loosen the hose pinch by turning it counter-clockwise a couple of turns.
    • Continue to loosen the hose pinch by hand until it comes free from its threads.
    • Slide the hose pinch up the tube so that it does not interfere with removing the hose.
  2. Lezyne CNC Dirt Floor Drive Hose Replacement: stap 2, afbeelding 1 van 3 Lezyne CNC Dirt Floor Drive Hose Replacement: stap 2, afbeelding 2 van 3 Lezyne CNC Dirt Floor Drive Hose Replacement: stap 2, afbeelding 3 van 3
    • Carefully slice a slit in the base of the hose with a hobby knife.
    • Be careful and go slowly so as not to damage the nipple underneath.
    • Use a metal prying tool or flathead screwdriver to pry the hose off of the nipple.
    • Remove the hose from the pump.
  3. Lezyne CNC Dirt Floor Drive Hose Replacement: stap 3, afbeelding 1 van 2 Lezyne CNC Dirt Floor Drive Hose Replacement: stap 3, afbeelding 2 van 2
    • Slide the hose pinch off of the end of the old hose and onto the new hose.
    • Be sure that the threaded end of the hose pinch faces toward the open end of the new hose.
  4. Lezyne CNC Dirt Floor Drive Hose Replacement: stap 4, afbeelding 1 van 3 Lezyne CNC Dirt Floor Drive Hose Replacement: stap 4, afbeelding 2 van 3 Lezyne CNC Dirt Floor Drive Hose Replacement: stap 4, afbeelding 3 van 3
    • Before you slide the new hose on, it may help to dip the end of the new hose in soapy water to make installation easier. Just be sure that there is no water in the hose when you re-install it.
    • Press the new hose onto the nipple until the hose touches the base of the pump.
    • Push down on the hose clamp while twisting it clockwise to thread it in place.
Eindstreep
iRobot
1 Reputatie
636 handleidingen geschreven
2 opmerkingen
It is really difficult to loosen the hose pinch with a nose plier. Maintenance is a nightmare with this pump. replacing the gauge is again extremely difficult. Badly engineered product.
saleembaig1234 - Antwoord
I found if you place the pump on its handle, having already loosened the threaded pinch hose cover (the one at the base of the pump) grip the hose with regular pliers being careful not to squeeze too hard, pull sharply downwards and the hose comes away easily enough and without having to cut the hose. Hope this helps somebody as this guide has helped me. Thank you
Pemble - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 1,976
