Ga door naar hoofdinhoud
Lezyne CNC Dirt Floor Drive Gauge Replacement
Wat je nodig hebt
  1. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: stap 1, afbeelding 1 van 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Cover: stap 1, afbeelding 2 van 2
    • Using a flat head screwdriver, pry up an edge of the gauge cover.
    • Remove the gauge cover.
  2. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: stap 2, afbeelding 1 van 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Gauge Face Plate and Internals: stap 2, afbeelding 2 van 2
    • No parts from the old gauge will be re-used, so there is no need to attempt to preserve the parts. However, be careful not to damage the gauge housing.
    • Pry up a corner of the gauge face plate.
    • Use pliers to pull off the gauge face plate.
    • Be careful when prying off the face plate, as the edges are sharp.
    • Use pliers to remove the internal gauge mechanics.
  3. Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: stap 3, afbeelding 1 van 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Removing the Old Gauge: stap 3, afbeelding 2 van 2
    • Using pliers, grip the exposed brass piece and unthread the gauge by rotating the gauge counter-clockwise.
    • Pull the gauge out of its housing.
  4. Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: stap 4, afbeelding 1 van 2 Lezyne CNC Dirt Floor Drive Gauge Replacement, Replacing the Gauge O-rings: stap 4, afbeelding 2 van 2
    • Remove the O-ring that is at the bottom of the threaded hole that the gauge threaded into.
    • Place a new O-ring into the hole.
  5. Lezyne CNC Dirt Floor Drive Gauge Replacement, Applying Threadlocker: stap 5, afbeelding 1 van 1
    • Apply medium-strength Loctite (green, 290) to the threads of the new gauge.
  6. Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: stap 6, afbeelding 1 van 3 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: stap 6, afbeelding 2 van 3 Lezyne CNC Dirt Floor Drive Gauge Replacement, Installing the New Gauge: stap 6, afbeelding 3 van 3
    • Thread the new gauge into the floor pump by turning it clockwise in its housing.
    • Thread the gauge until it is snug and the BAR/psi markings are aligned with the pump body.
    • Gauge performance will not be affected by its position, so long as it is snug.
    • Allow at least 30 minutes for the thread locker to set.
    • Test pump to its highest rated pressure and listen for leaks. If you can hear leaks from the gauge, tighten it.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
7 opmerkingen
i use both gold and silver bracelets because for me, they are both great bracelets to wear;; <a href="https://www.chinamaijin.com/">cnc machining</a>
saif 77 - Antwoord
Its good  as your other  content  : D,  appreciate it for posting . <a href="https://www.chinamaijin.com/">cnc machining parts</a>
saif 77 - Antwoord
I feel nice about it and love learning more about this topic. <a href="https://certifiedbourbon.com/product/blu...">blue label for sale</a> I will come to your site to find out more and tell my acquaintances about you.
Biplob Chandra Singha - Antwoord
Nice information and good tips for SEO off-page optimization. I have got good tips to improve SEO off-page Optimization. Thanks for sharing! <a href="https://certifiedbourbon.com/product/pap...>pappy van winkle online</a> please keep it up Maintains!
legalweed suppliers - Antwoord
I was checking continuously this list and I’m impressed! Extremely useful info especially this blog commenting sites list. <a href="https://mushroomlux.com/product/dmt-cart...>purecybin dmt</a> Thank you and best of luck.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 5,466
