Ga door naar hoofdinhoud
Lexmark Intuition S505 Ink Cartridges Replacement
  1. Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: stap 1, afbeelding 1 van 2 Lexmark Intuition S505 Ink Cartridges Replacement, Ink Cartridges: stap 1, afbeelding 2 van 2
    • Lift the scanning unit, exposing the print head.
  2. Lexmark Intuition S505 Ink Cartridges Replacement: stap 2, afbeelding 1 van 1
    • Locate the frame around the ink cartridges. Press the button located at the front of the cartridge frame.
  3. Lexmark Intuition S505 Ink Cartridges Replacement: stap 3, afbeelding 1 van 1
    • Lift the frame to expose the ink cartridges.
  4. Lexmark Intuition S505 Ink Cartridges Replacement: stap 4, afbeelding 1 van 1
    • Push the button located above the designated ink cartridge until it pops out.
  5. Lexmark Intuition S505 Ink Cartridges Replacement: stap 5, afbeelding 1 van 1
    • Pull the cartridge out, and place the new ink cartridge back into the slot. Push until you hear a click.
  6. Lexmark Intuition S505 Ink Cartridges Replacement: stap 6, afbeelding 1 van 2 Lexmark Intuition S505 Ink Cartridges Replacement: stap 6, afbeelding 2 van 2
    • Close the scanner unit.
Conclusie
Once your ink cartridges are in place, your printer should now print high-quality documents.
Omar
111 Reputatie
2 handleidingen geschreven
Cal Poly, Team 18-38, Regan Winter 2013 Lid van Cal Poly, Team 18-38, Regan Winter 2013
CPSU-REGAN-W13S18G38
4 Leden
8 handleidingen geschreven
Één opmerking
Hello there, thanks for your demonstration. In case that the cartridges are not genuine (not a lexmark brand), will the printer will be able to print?
I own this model. Thanks in advance!
Dimitri Sideris - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 4
Altijd: 3,238
