Ga door naar hoofdinhoud
Lens Cover Replacement
Wat je nodig hebt
  1. Lens Cover Replacement, Lens Cover: stap 1, afbeelding 1 van 1
    • Unscrew the two small screws on the black side panel of the camera using a PH00 screwdriver. Remove the part.
  2. Lens Cover Replacement: stap 2, afbeelding 1 van 1
    • You will need to remove the front panel in order to access the lens. Lift the latches on the side of the front panel to remove it entirely, pulling gently in an upward motion.
  3. Lens Cover Replacement: stap 3, afbeelding 1 van 1
    • Locate silver lens covering.
  4. Lens Cover Replacement: stap 4, afbeelding 1 van 1
    • Use your PH00 screwdriver to unscrew the lens cover.
    • Remove the screw.
    • Remove the lens cover.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kathleen
225 Reputatie
2 handleidingen geschreven
Één opmerking
I found that additional steps are needed between steps 2 and 3 to remove 5 additional screws before the front panel can be removed.
Was my Olympus 850 SW different from the one repaired in that tutorial?
I took pictures that I could insert in the tutorial, but did not find how to do it.
Michel
Michel Martin - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 13
Altijd: 935
