Ga door naar hoofdinhoud
Lenovo bluetooth mouse N6901A disassembly
Wat je nodig hebt
  1. Lenovo bluetooth mouse N6901A disassembly, Mouse: stap 1, afbeelding 1 van 1
    • 3 Phillips screws are located under the battery cover, unscrew them
  2. Lenovo bluetooth mouse N6901A disassembly: stap 2, afbeelding 1 van 2 Lenovo bluetooth mouse N6901A disassembly: stap 2, afbeelding 2 van 2
    • The mouse cover at the bottom should move freely but at the top is hold by 2 brackets
    • In order to remove the mouse cover, you will need to rock left/right the cover and slide it down (from scroll wheel toward the Lenovo logo)
  3. Lenovo bluetooth mouse N6901A disassembly: stap 3, afbeelding 1 van 2 Lenovo bluetooth mouse N6901A disassembly: stap 3, afbeelding 2 van 2
    • At this point, you have separated the mouse cover
  4. Lenovo bluetooth mouse N6901A disassembly: stap 4, afbeelding 1 van 1
    • Use the appropriate tool to remove gently the power connector. Don't use your finger, you might brake the cable
  5. Lenovo bluetooth mouse N6901A disassembly: stap 5, afbeelding 1 van 2 Lenovo bluetooth mouse N6901A disassembly: stap 5, afbeelding 2 van 2
    • The micro switch can be replaced by OMRON D2FC-F-7N but you need to trim the solder terminals with a flush wire cutter
    • When you reassemble the mouse, make sure you don't crush the power cable
Conclusie
Shinn Chyang Chen
2.953 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 36
Altijd: 5,543
