Ga door naar hoofdinhoud
Lenovo Z70-80 Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Z70-80 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 2 Lenovo Z70-80 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 2
    • Use your fingers two push both latches away from each other to release the battery.
    • Pull the battery out.
  2. Lenovo Z70-80 Motherboard Replacement, Back Panel: stap 2, afbeelding 1 van 3 Lenovo Z70-80 Motherboard Replacement, Back Panel: stap 2, afbeelding 2 van 3 Lenovo Z70-80 Motherboard Replacement, Back Panel: stap 2, afbeelding 3 van 3
    • Remove the two Phillips #0 screws from the bottom panel.
    • Slide the panel down slightly, and then lift to pull it off.
  3. Lenovo Z70-80 Motherboard Replacement, Optical Drive: stap 3, afbeelding 1 van 3 Lenovo Z70-80 Motherboard Replacement, Optical Drive: stap 3, afbeelding 2 van 3 Lenovo Z70-80 Motherboard Replacement, Optical Drive: stap 3, afbeelding 3 van 3
    • Remove the single 3mm Phillips #0 screw from the optical drive.
    • Pull the optical drive out of the side.
  4. Lenovo Z70-80 Motherboard Replacement, Electric Fan: stap 4, afbeelding 1 van 3 Lenovo Z70-80 Motherboard Replacement, Electric Fan: stap 4, afbeelding 2 van 3 Lenovo Z70-80 Motherboard Replacement, Electric Fan: stap 4, afbeelding 3 van 3
    • Remove the three 6mm Phillips #0 screws from the fan.
    • Disconnect the fan from the motherboard by pulling up on the plug.
  5. Lenovo Z70-80 Motherboard Replacement, Motherboard: stap 5, afbeelding 1 van 1
    • Remove all the 17 7mm Phillips #0 screws.
    • A sticker covers this screw. Remove this sticker to remove the screw.
    • Remove the back cover.
  6. Lenovo Z70-80 Motherboard Replacement: stap 6, afbeelding 1 van 3 Lenovo Z70-80 Motherboard Replacement: stap 6, afbeelding 2 van 3 Lenovo Z70-80 Motherboard Replacement: stap 6, afbeelding 3 van 3
    • Pry the edges of the keyboard upwards using a spudger.
    • A cable with a ZIF connector is attached to the bottom of the keyboard. Flip the small black tab on the connector for safe removal.
    • Remove the five 3mm Phillips #0 screws.
  7. Lenovo Z70-80 Motherboard Replacement: stap 7, afbeelding 1 van 3 Lenovo Z70-80 Motherboard Replacement: stap 7, afbeelding 2 van 3 Lenovo Z70-80 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Remove all the ribbon cables and connectors from the front and back of the laptop.
    • Remember to flip the small black tabs on ZIF connectors for safe removal.
  8. Lenovo Z70-80 Motherboard Replacement: stap 8, afbeelding 1 van 2 Lenovo Z70-80 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Remove the 3mm screw and carefully pull out the cables from the hooks holding them in place.
  9. Lenovo Z70-80 Motherboard Replacement: stap 9, afbeelding 1 van 2 Lenovo Z70-80 Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Use a spudger at the edges of the laptop cover to carefully pry upwards, removing the cover.
  10. Lenovo Z70-80 Motherboard Replacement: stap 10, afbeelding 1 van 3 Lenovo Z70-80 Motherboard Replacement: stap 10, afbeelding 2 van 3 Lenovo Z70-80 Motherboard Replacement: stap 10, afbeelding 3 van 3
    • Unplug the two black cables from the motherboard.
    • Remove the three 3mm screws from the motherboard.
    • Remove the motherboard.
    • Pick up the motherboard carefully by the edges.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Bijgevoegde documenten
Eduardo Delgado
412 Reputatie
4 handleidingen geschreven
Gateway, Team S1-G4, Johnson Spring 2018 Lid van Gateway, Team S1-G4, Johnson Spring 2018
GCC-JOHNSON-S18S1G4
2 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 41
Altijd: 4,021
