Inleiding
This guide will demonstrate how to replace the keyboard on your Lenovo Z70-80 laptop.
Wat je nodig hebt
Use your fingers two push both latches away from each other to release the battery.
Pull the battery out.
Carefully pry up the keyboard with the flat end of a spudger and remove all of the 3mm Phillips #0 screws.
Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF socket.
Pull the keyboard cable out of the socket.
Remove the keyboard.
Één andere persoon heeft deze handleiding voltooid.
