Ga door naar hoofdinhoud
Lenovo Yoga Tablet 2 830-F Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw on the back fo the device with a Phillips #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: stap 2, afbeelding 1 van 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the six 3mm screws on the back of the motherboard with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Remove ZIF connectors connecting the boards to the electrical components.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Motherboard Replacement: stap 3, afbeelding 1 van 2 Lenovo Yoga Tablet 2 830-F Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Replace the motherboard with the new motherboard.
    • Be careful not to damage the ribbon cables when reassembling the device.
Conclusie
Charles Rhode
588 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G4, Nance Fall 2017 Lid van USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 1,957
