Ga door naar hoofdinhoud
Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement
Wat je nodig hebt
  1. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 1 van 2 Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement, Headphone Jack: stap 1, afbeelding 2 van 2
    • Remove the two 3mm screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Remove the 2mm screw with a Phillips #00 bit.
    • Using the blue opening tool or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: stap 2, afbeelding 1 van 1
    • Remove the three 2mm screws on the back of the left speaker module with the Phillips Screwdriver #00 bit.
    • Remove the ribbon cables connecting the boards to the other electrical components
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Headphone Jack Replacement: stap 3, afbeelding 1 van 1
    • Gently remove the left speaker module.
    • Replace the old left speaker module with the new left speaker module.
    • Be careful not to damage the ribbon cables on the new left speaker module while reassembling the device.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Charles Rhode
588 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G4, Nance Fall 2017 Lid van USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 26
Altijd: 1,920
