Ga door naar hoofdinhoud
Lenovo Yoga Tablet 2 830-F Camera Replacement
Wat je nodig hebt
  1. Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: stap 1, afbeelding 1 van 2 Lenovo Yoga Tablet 2 830-F Camera Replacement, Camera: stap 1, afbeelding 2 van 2
    • Remove the three screws on the back of the device with the Phillips Screwdriver #00 bit.
    • Using the blue opening tools or spudger, gently remove the back cover to expose the interior of the tablet.
  2. Lenovo Yoga Tablet 2 830-F Camera Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: stap 2, afbeelding 3 van 3
    • Using the Phillips Screwdriver #00 bit remove the 6 screws.
    • Using the Phillips Screwdriver #00 bit remove the 3 screws.
    • After removing all the screws, disconnect the ribbon cables.
    • Disconnect the ZIF connectors.
    • Some of the ribbon cables are secured with clips, simply pry up the clips before sliding them out of the pin connectors.
  3. Lenovo Yoga Tablet 2 830-F Camera Replacement: stap 3, afbeelding 1 van 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: stap 3, afbeelding 2 van 3 Lenovo Yoga Tablet 2 830-F Camera Replacement: stap 3, afbeelding 3 van 3
    • After removing the motherboard and antennas the camera module is located on the right as marked in red.
    • Remove the three 2mm screws holding the module in place with the Phillips Screwdriver #00 bit.
    • The camera module is also held in place with adhesive so gently remove.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Mario Gjyli
447 Reputatie
3 handleidingen geschreven
USF Tampa, Team S2-G4, Nance Fall 2017 Lid van USF Tampa, Team S2-G4, Nance Fall 2017
USFT-NANCE-F17S2G4
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 7
Altijd: 652
