Ga door naar hoofdinhoud
Lenovo Yoga Tab 3 10 Wifi Module Replacement
Wat je nodig hebt
  1. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Open the built-in kickstand.
  2. Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 2, afbeelding 3 van 3
    • Remove the sticker located directly under the the built-in kickstand to reveal two 0.75 mm screws.
    • Remove the microSD card slot cover. Remove any microSD card (if inserted).
    • Using a Phillips head screwdriver, remove the three 0.75 mm screws.
  3. Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 3, afbeelding 1 van 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 3, afbeelding 2 van 3 Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 3, afbeelding 3 van 3
    • Orient the device so the screen is facing you.
    • Carefully insert the spudger along the seam between the screen and back cover and gently separate the back cover from the device frame.
    • Continue to detach the backplate from the frame by moving the spudger around the perimeter.
    • Some force will be required to detach the small plastic braces securing the backplate to the device.
  4. Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: stap 4, afbeelding 1 van 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement, Wifi Module: stap 4, afbeelding 2 van 2
    • Use the nylon spudger to gently lift the foil cover of the wifi model.
  5. Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Koop
    • Use tweezers to gently lift the gold tape located above the copper foil.
  6. Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic spudger to disconnect the wifi module connector from the motherboard.
  7. Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 7, afbeelding 1 van 2 Lenovo Yoga Tab 3 10 Wifi Module Replacement: stap 7, afbeelding 2 van 2
    • Carefully lift the wifi module from the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Phanudej
1.187 Reputatie
5 handleidingen geschreven
USF Tampa, Team S3-G2, Sullivan Spring 2017 Lid van USF Tampa, Team S3-G2, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G2
4 Leden
18 handleidingen geschreven
Één opmerking
where can i buy this type of module?
rebeca rackolavsci - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 32
Altijd: 3,536
