Ga door naar hoofdinhoud
Lenovo Yoga C930-13IKB Back Cover Replacement
Wat je nodig hebt
  1. Lenovo Yoga C930-13IKB Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Flip the device over so that the underside is facing up.
    • Remove the six 3.5 mm T5 Torx screws.
  2. Lenovo Yoga C930-13IKB Back Cover Replacement: stap 2, afbeelding 1 van 2 Lenovo Yoga C930-13IKB Back Cover Replacement: stap 2, afbeelding 2 van 2
    • Pry off the back cover using the plastic opening tool.
    • Loosen the back cover in multiple spots using the opening tool, then remove the whole back.
    • You may have to run the plastic tool along the edges until you find a small gap to separate the back cover from the laptop.
    • Do not use a metal tool when working with your device.
  3. Lenovo Yoga C930-13IKB Back Cover Replacement: stap 3, afbeelding 1 van 2 Lenovo Yoga C930-13IKB Back Cover Replacement: stap 3, afbeelding 2 van 2
    • Carefully lift the cover off with your hands.
Conclusie
Hanna Lazkani
824 Reputatie
3 handleidingen geschreven
Cal Poly, Team S19-G5, White Winter 2020 Lid van Cal Poly, Team S19-G5, White Winter 2020
CPSU-WHITE-W20S19G5
4 Leden
16 handleidingen geschreven
Één opmerking
On mine, not T5 but T4. Also screw holding the chip in is philips 000.
Jim Steele - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 55
Altijd: 3,275
