Ga door naar hoofdinhoud
Lenovo Yoga 2 Pro Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 2 Pro Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Please ensure that the laptop is turned off before beginning.
    • Using a Phillips #00 screwdriver, remove the eleven 1/4" screws from the back of the laptop.
  2. Lenovo Yoga 2 Pro Battery Replacement: stap 2, afbeelding 1 van 1
    • Gently unclip and lift off the back cover.
  3. Lenovo Yoga 2 Pro Battery Replacement: stap 3, afbeelding 1 van 1
    • Using a Phillips #00 Screwdriver, remove the five 5/16" screws surrounding the battery.
  4. Lenovo Yoga 2 Pro Battery Replacement: stap 4, afbeelding 1 van 1
    • Using either tweezers or your fingers, disconnect the black battery cable by pinching either side of the connector and pulling towards the battery.
  5. Lenovo Yoga 2 Pro Battery Replacement: stap 5, afbeelding 1 van 2 Lenovo Yoga 2 Pro Battery Replacement: stap 5, afbeelding 2 van 2
    • Remove the battery from the computer.
Conclusie
34 andere personen hebben deze handleiding voltooid.
Thomas Simko
2.511 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-14, Maness Fall 2015 Lid van Cal Poly, Team 12-14, Maness Fall 2015
CPSU-MANESS-F15S12G14
5 Leden
12 handleidingen geschreven
13 opmerkingen
The cover does not come off “gently”- there are snaps all the way around that must be popped.
Colin Leitner - Antwoord
where do I buy a quality replacement battery?
I checked ebay and amazon, and there are a bunch of them. But I don’t know which one I should buy.
Thanks in advance.
Can Coin - Antwoord
Did you find a suitable replacement? I’m curious too - looks like prices are $60 or twice that. Worth paying more than bargain basement prices?
drwelby -
You can get a Lenovo replacement battery from Amazon. About US 46. Did it, replaced, but now machine says no battery installed! Have searched far and wide on the web, but haven’t found an answer. Lots of complaints that Lenovo and new battery don’t mix well. Still searching. BTW I bought the replacement per my comments above. It’s an exact match and they put black tap over the Lenovo name.
msalvatini - Antwoord
Might work with #00 Phillips driver (haven’t tried yet), but they sure look like mini Torx heads on mine (star shaped).
christian - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 92
Altijd: 47,210
