Ga door naar hoofdinhoud
Lenovo Yoga 910-13IKB SSD Replacement
Wat je nodig hebt
  1. Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: stap 1, afbeelding 1 van 2 Lenovo Yoga 910-13IKB SSD Replacement, Bottom Panel: stap 1, afbeelding 2 van 2
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel.
    • Remove the panel.
  2. Lenovo Yoga 910-13IKB SSD Replacement: stap 2, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the four M2 x 1.7 mm screws securing the battery to the laptop.
    • Remove the battery.
  3. Lenovo Yoga 910-13IKB SSD Replacement: stap 3, afbeelding 1 van 1
    • Remove the six Phillips screws that attach the trackpad to the device.
    • Use a spudger to disconnect the ribbon cable connector from the trackpad.
    • Remove the trackpad using a spudger.
  4. Lenovo Yoga 910-13IKB SSD Replacement: stap 4, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove six screws attached to the USB ports on both sides of the device.
    • Detach both ribbon cables attached to each USB port with a spudger, then detach the USB ports.
  5. Lenovo Yoga 910-13IKB SSD Replacement: stap 5, afbeelding 1 van 2 Lenovo Yoga 910-13IKB SSD Replacement: stap 5, afbeelding 2 van 2
    • Use a small Phillips screwdriver to remove all single screw securing the SSD stick to the motherboard.
    • Slide the SSD stick from the port on the motherboard.
  6. Lenovo Yoga 910-13IKB SSD Replacement: stap 6, afbeelding 1 van 3 Lenovo Yoga 910-13IKB SSD Replacement: stap 6, afbeelding 2 van 3 Lenovo Yoga 910-13IKB SSD Replacement: stap 6, afbeelding 3 van 3
    • Use a small Phillips screwdriver to remove four screws from the fans.
    • Remove the back connector strip using a spudger to pry it off of the device.
    • Remove the fans.
    • Now, only the bottom panel should remain.
  7. Lenovo Yoga 910-13IKB SSD Replacement, SSD: stap 7, afbeelding 1 van 1
    • Remove the 3mm JIS #00 screw holding the storage in place.
  8. Lenovo Yoga 910-13IKB SSD Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga 910-13IKB SSD Replacement: stap 8, afbeelding 2 van 2
    • Pull up lightly on the drive and gently pull it out of the connector.
Conclusie
Nikhil Nagarajan
97 Reputatie
1 Handleiding geschreven
Cal Poly, Team S1-G5, White Winter 2020 Lid van Cal Poly, Team S1-G5, White Winter 2020
CPSU-WHITE-W20S1G5
4 Leden
14 handleidingen geschreven
1Gids Commentaar
Just one question: if I want to replace just the SSD, surely one goes straight from step one to step seven?
Bessi Aðalsteinsson - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 42
Altijd: 7,075
