Inleiding
The Lenovo Yoga 910-13IKB is a dynamic laptop with tablet-like features. In this guide, you will be walked through each step needed to replace the fan, which will eventually break or become inoperable due to wear and tear from regular usage. The fan is a vital component, as it cools down the CPU when the laptop is in use. If you notice that the fan is silent, that the air near the vents is calm, or that your laptop is especially hot, it is likely time to consider replacing your fan. The replacement process can be completed without any technical skills, all that is needed is a bit of patience.
Wat je nodig hebt
Turn the laptop over and remove the ten Torx T5 screws along the perimeter of the bottom panel using the T5 Torx Screwdriver.
Remove the back panel from the device exposing the components.
Remove the screws attached to the SSD stick by using a Phillips #0 screwdriver.
Pull the SSD stick directly to the right until it shifts out of place to remove it.
To reassemble your device, follow steps 1-8 in reverse order.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
This laptop throttles like crazy with heavy load even if both fans are working perfectly!
