Inleiding
This step-by-step repair guide will show you how to replace the keyboard in the 13 inch Lenovo Yoga 900. Whether you have a malfunctioning key or the whole keyboard has ceased to work, replacing your keyboard will get you back to typing. Fortunately, the keyboard in the Yoga 900-13ISK is modular, so you can replace it without needing to replace the entire palm rest.
Gereedschap
Onderdelen
Geen onderdelen opgegeven.
Using a T5 Torx screwdriver, remove the ten 5.5 mm screws from the back case of the laptop.
Remove the five 3.6 mm screws from the battery with a Phillips #00 screwdriver.
Use a Phillips #00 screwdriver to remove the 2.7 mm screw that is holding down the SSD card.
Pry up the white and black coaxial cables from the Wi-Fi card using a spudger.
Move the cables to the side.
Using the pointed end of a spudger, flip up the locking tabs of the eight ZIF connectors on the motherboard.
Pull the eight cables out from their connectors using a pair of blunt nose tweezers.
Remove the two 3.5 mm screws from the charging port with a Phillips #00 screwdriver.
Remove the 3.6 mm screw from the daughterboard on the right with a Phillips #00 screwdriver.
