Ga door naar hoofdinhoud
Lenovo Yoga 730-13IKB Storage Replacement
Wat je nodig hebt
  1. Lenovo Yoga 730-13IKB Storage Replacement, Back Case: stap 1, afbeelding 1 van 3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: stap 1, afbeelding 2 van 3 Lenovo Yoga 730-13IKB Storage Replacement, Back Case: stap 1, afbeelding 3 van 3
    • Power off the laptop and place it facedown on a non-scratching surface.
    • Remove the nine T5 screws fastening the back case.
  2. Lenovo Yoga 730-13IKB Storage Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 730-13IKB Storage Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 730-13IKB Storage Replacement: stap 2, afbeelding 3 van 3
    • Slide a plastic opening tool underneath the back case near the screen hinges. Gently pry up on either side.
    • Slide the opening tool underneath the back case next to the middle screw hole at either side of the case. Gently pry up.
    • You may hear popping sounds as the tabs securing the case release. This is normal. If the case does not move, try prying at a different angle/position.
  3. Lenovo Yoga 730-13IKB Storage Replacement: stap 3, afbeelding 1 van 1
    • Remove the back case by pulling up near the screen hinges and lifting diagonally away from the laptop.
    • Go slowly to avoid breaking any connecting tabs.
  4. Lenovo Yoga 730-13IKB Storage Replacement, Storage: stap 4, afbeelding 1 van 1
    • Use a Phillips #00 screwdriver to remove the 4mm screw holding down the storage drive.
  5. Lenovo Yoga 730-13IKB Storage Replacement: stap 5, afbeelding 1 van 2 Lenovo Yoga 730-13IKB Storage Replacement: stap 5, afbeelding 2 van 2
    • Hold onto the back of the storage drive and slightly lift up.
    • Remove the drive by pulling back at a diagonal angle.
    • To install the storage drive, insert it into the connector at a slight downwards angle. The drive connector is keyed and will only go in one way.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Colin Reay
848 Reputatie
5 handleidingen geschreven
Cal Poly, Team S1-G1, White Winter 2020 Lid van Cal Poly, Team S1-G1, White Winter 2020
CPSU-WHITE-W20S1G1
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 34
Altijd: 1,390
