Ga door naar hoofdinhoud
Lenovo Yoga 720-15IKB Wireless Adapter Replacement
Wat je nodig hebt
  1. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: stap 2, afbeelding 1 van 2 Lenovo Yoga 720-15IKB Wireless Adapter Replacement: stap 2, afbeelding 2 van 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: stap 3, afbeelding 1 van 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: stap 3, afbeelding 2 van 3 Lenovo Yoga 720-15IKB Wireless Adapter Replacement, Wireless Adapter: stap 3, afbeelding 3 van 3
    • Lift the foam covering the connecting wires and screw, and use the Phillips #0 screwdriver to remove the 2mm screw.
  4. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: stap 4, afbeelding 1 van 1
    • Grab the adapter from both sides and pull towards the hinge to remove the adapter from the device.
  5. Lenovo Yoga 720-15IKB Wireless Adapter Replacement: stap 5, afbeelding 1 van 1
    • Remove the black and white wires from the adapter by pulling up on each wire.
    • When reassembling, make sure to press each wire connector firmly onto the new adapter to make sure it is a secure fit.
Conclusie
Matthew Bornhorst
495 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G3, White Winter 2020 Lid van Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Leden
25 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 11
Altijd: 783
