Ga door naar hoofdinhoud
Lenovo Yoga 720-15IKB Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 Lenovo Yoga 720-15IKB Battery Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    • Power off the device before starting.
    • Flip the device over with the hinges facing away from you.
    • Remove seven 5.0 mm Torx T5 screws.
    • Remove three 9.5 mm Torx T5 screws.
  2. Lenovo Yoga 720-15IKB Battery Replacement: stap 2, afbeelding 1 van 2 Lenovo Yoga 720-15IKB Battery Replacement: stap 2, afbeelding 2 van 2
    • Pry around the edges from one side to another with a plastic opening tool.
    • Do not pry on the side with the hinges because this can break the cover.
    • Lift the case from the front until you feel resistance.
    • Do not keep lifting after you feel resistance, or the bottom cover can break.
    • Pull the cover towards you, away from the hinges.
    • Completely lift off the cover.
  3. Lenovo Yoga 720-15IKB Battery Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo Yoga 720-15IKB Battery Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the four 4mm screws surrounding the battery with a Phillips #0 screwdriver.
    • Each is marked by "M2x5" with a small white arrow pointing to the screw itself.
  4. Lenovo Yoga 720-15IKB Battery Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 720-15IKB Battery Replacement: stap 4, afbeelding 2 van 2
    • Pull firmly on the battery connector to disconnect it.
  5. Lenovo Yoga 720-15IKB Battery Replacement: stap 5, afbeelding 1 van 1
    • Lift the battery out of the case to remove it.
Conclusie
11 andere personen hebben deze handleiding voltooid.
Matthew Bornhorst
510 Reputatie
2 handleidingen geschreven
Cal Poly, Team S19-G3, White Winter 2020 Lid van Cal Poly, Team S19-G3, White Winter 2020
CPSU-WHITE-W20S19G3
4 Leden
25 handleidingen geschreven
6 opmerkingen
Excellent guide. Made the job a snap. Especially identifying the screwdriver bit requird.
James Smith - Antwoord
Good guide. Fairly easy project. Getting the battery connector back in on the replacement battery was by far the hardest part. Be patient with it. It took me a few tries, but it slid in fairly easily once it was all lined up correctly.
Mark Haakenson - Antwoord
Thank you for the great informative guide! ordering my battery and tools now!
justmelendez - Antwoord
The new battery is not recognized after installation.
The plug is very loose. Is that normal? But I can't plug it in any further
Stefan - Antwoord
Having the exact same problem. If you've figured it out, please let me know.
Riley -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 12
Afgelopen 7 dagen: 48
Afgelopen 30 dagen: 177
Altijd: 13,666
