Inleiding
This guide will show you how to replace the wireless adapter.
Wat je nodig hebt
Gereedschap gebruikt in deze stap:JIS Driver Set$19.99
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Pull the battery towards you until the wire is accessible.
gently tug and wiggle on the wire until it pops out.
Remove the battery.
6 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Just wanted to add I just swapped my 720-13IKB’s wifi module for a Intel AX200 (Only version i could buy was in a “desktop kit”)
and it worked out of the box! AX201 / AX210 or newer are a different kind of m.2 wifi and wont work with the 720 13IKB according to reddit.
Now I’m easily getting 350 down on my 5Ghz 40HT (Wifi6 WPA3) network!, Old card didn’t support my new WPA3 wifi and could only get 100ish down.
