Ga door naar hoofdinhoud
Lenovo Yoga 720 Speaker Replacement
Wat je nodig hebt
  1. Lenovo Yoga 720 Speaker Replacement, Bottom Cover: stap 1, afbeelding 1 van 3 Lenovo Yoga 720 Speaker Replacement, Bottom Cover: stap 1, afbeelding 2 van 3 Lenovo Yoga 720 Speaker Replacement, Bottom Cover: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    T5 Torx Screwdriver
    $5.49
    Koop
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Start by flipping the device over so that you see the screws.
    • Remove seven Torx T5 short screws.
    • Remove three Torx T5 long screws.
  2. Lenovo Yoga 720 Speaker Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 720 Speaker Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 720 Speaker Replacement: stap 2, afbeelding 3 van 3
    iFixit Opening Tool
    $1.99
    Koop
    • Starting from the USB port, use your opening tool to gently pry up the case.
    • Make sure you are prying on the cover itself, not the metal shield around the USB port.
    • Pry along the laptop in the order shown by the arrows.
    • Do NOT pry along the top side, or you risk damaging the casing. Stay with the arrows.
  3. Lenovo Yoga 720 Speaker Replacement: stap 3, afbeelding 1 van 3 Lenovo Yoga 720 Speaker Replacement: stap 3, afbeelding 2 van 3 Lenovo Yoga 720 Speaker Replacement: stap 3, afbeelding 3 van 3
    • Lift the case from the bottom side. NOT the side with the hinges.
    • When you feel resistance, do NOT keep lifting or you will damage the housing.
    • Once you feel resistance, gently pull the case towards you. (away from the hinges.)
    • Remove the case.
  4. Lenovo Yoga 720 Speaker Replacement, Battery: stap 4, afbeelding 1 van 3 Lenovo Yoga 720 Speaker Replacement, Battery: stap 4, afbeelding 2 van 3 Lenovo Yoga 720 Speaker Replacement, Battery: stap 4, afbeelding 3 van 3
    JIS Driver Set
    $19.99
    Koop
    • This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
    • Be careful not to short anything on the motherboard, as the battery cannot be disconnected before removal.
    • Remove four J1 Philips screws.
    • Remove one J1 philips screw.
    • Do not mix these screws up. If you put the longer screw where the shorter screw belongs, you will damage the shield around the keyboard.
    • Lift the battery slightly using your plastic opening tool.
    • Do not lift the battery out all the way, as it is still connected to the motherboard.
    • Do NOT puncture or deform the battery or it may catch fire or even explode.
  5. Lenovo Yoga 720 Speaker Replacement: stap 5, afbeelding 1 van 3 Lenovo Yoga 720 Speaker Replacement: stap 5, afbeelding 2 van 3 Lenovo Yoga 720 Speaker Replacement: stap 5, afbeelding 3 van 3
    • Pull the battery towards you until the wire is accessible.
    • gently tug and wiggle on the wire until it pops out.
    • Remove the battery.
  6. Lenovo Yoga 720 Speaker Replacement, Speaker: stap 6, afbeelding 1 van 2 Lenovo Yoga 720 Speaker Replacement, Speaker: stap 6, afbeelding 2 van 2
    $3.99
    Koop
    • Disconnect the speakers.
  7. Lenovo Yoga 720 Speaker Replacement: stap 7, afbeelding 1 van 3 Lenovo Yoga 720 Speaker Replacement: stap 7, afbeelding 2 van 3 Lenovo Yoga 720 Speaker Replacement: stap 7, afbeelding 3 van 3
    • Remove the left speaker.
    • Remove the Adhesive.
    • Use this pull tab to remove it.
    • Remove the right speaker,
Conclusie
5 andere personen hebben deze handleiding voltooid.
Aiden
17.486 Reputatie
21 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 14
Altijd: 1,790
