Inleiding
This guide will show you how to remove the fingerprint reader.
Wat je nodig hebt
Remove seven Torx T5 short screws.
Remove three Torx T5 long screws.
Starting from the USB port, use your opening tool to gently pry up the case.
Pry along the laptop in the order shown by the arrows.
This is the battery. For guides that are for other parts, the battery is removed for the reason of it being a pain to connect or disconnect while screwed in.
Remove four J1 Philips screws.
Remove one J1 philips screw.
Lift the battery slightly using your plastic opening tool.
Remove the bracket,
Remove the fingerprint reader.
6 andere personen hebben deze handleiding voltooid.
Één opmerking
Aiden,
How do I repair the power button on this model? It no longer clicks and I have to use a paper clip on the opposite side. Looks like I need to remove the motherboard to gain access
