Inleiding
This guide will show you how to replace the SSD in a Lenovo Yoga 710-15ISK laptop. The storage of your laptop is an essential component that determines how many programs or files your device can store. This model of laptop uses an M.2 SSD for its storage and can be replaced if you are lacking space. Be sure your replacement SSD is also an M.2 form factor—a SATA or mSATA may be cheaper, but will not be compatible.
Wat je nodig hebt
Flip your laptop over so the bottom is facing upwards.
Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
