Ga door naar hoofdinhoud
Lenovo Yoga 710-15ISK Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Back Cover: stap 1, afbeelding 2 van 2
    • Flip your laptop over so the bottom is facing upwards.
    • Remove ten 2 mm screws securing the back cover to the laptop using a Phillips #0 screwdriver.
  2. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Pry the back cover off of the laptop with your fingers.
  3. Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo Yoga 710-15ISK Motherboard Replacement, Battery: stap 3, afbeelding 2 van 2
    • Remove the four 2 mm screws from the battery using a Phillips #0 screwdriver.
  4. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the connector between the battery and the motherboard by gently pulling the black plastic-coated part of the wires.
  5. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery from the laptop.
  6. Lenovo Yoga 710-15ISK Motherboard Replacement, Fans: stap 6, afbeelding 1 van 1
    • Remove the four 1.5 mm screws from the fans with a Phillips #00 screwdriver.
  7. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Unplug the wire connecting the fan to the motherboard by gently pulling the white head from the port.
  8. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga 710-15ISK Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Lift both fans to remove them from the laptop.
  9. Lenovo Yoga 710-15ISK Motherboard Replacement, SSD: stap 9, afbeelding 1 van 1
    • Remove the sticker from the SSD to gain access to the screw underneath.
  10. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 10, afbeelding 1 van 2 Lenovo Yoga 710-15ISK Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Remove the screw holding the SSD in place using a Phillips #0 screwdriver.
    • Gently pull on the plastic clip next to the screw until the stick is freed and bounces up.
  11. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Slide the SSD out of the laptop.
  12. Lenovo Yoga 710-15ISK Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 1
    • Remove seven 2 mm screws from the motherboard using a Phillips #0 screwdriver.
  13. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 13, afbeelding 1 van 3 Lenovo Yoga 710-15ISK Motherboard Replacement: stap 13, afbeelding 2 van 3 Lenovo Yoga 710-15ISK Motherboard Replacement: stap 13, afbeelding 3 van 3
    • Unplug four cables attached to the motherboard.
    • For the flat ribbon wires, lift the black tabs holding them in place before removing them.
  14. Lenovo Yoga 710-15ISK Motherboard Replacement: stap 14, afbeelding 1 van 1
    • Carefully lift out the motherboard to remove it from the laptop.
Conclusie
Annette Limoges
181 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 Lid van UMass Dartmouth, Team 7-1, Sinclaire Spring 2022
UMASSD-SINCLAIRE-S22S7G1
5 Leden
8 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 6
Altijd: 258
