Ga door naar hoofdinhoud
Lenovo Yoga 710-14ISK Battery Replacement
Wat je nodig hebt
  1. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover screws: stap 1, afbeelding 1 van 1
    • Remove the M2 × 7 mm, Torx-head screws.
    • Remove the M2 × 5 mm, Torx-head screws.
  2. Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: stap 2, afbeelding 1 van 2 Lenovo Yoga 710-14ISK Battery Replacement, Remove the base cover: stap 2, afbeelding 2 van 2
    • Insert a prying tool (opening pick) between the base cover and the cover and slide it in the direction shown by arrows to separate the base cover from the cover.
    • Remove the base cover.
  3. Lenovo Yoga 710-14ISK Battery Replacement, Remove the battery: stap 3, afbeelding 1 van 1
    • Unplug the battery connector.
    • Remove the M2 × 3 mm, Phillips-head screws.
    • Remove the battery pack.
Conclusie
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
40.298 Reputatie
16 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
17.198 handleidingen geschreven
Één opmerking
Hi, do i can replace my laptop battery by myself? or i should go to geek squad in best buy.
Jesse Milani - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 632
