Ga door naar hoofdinhoud
Lenovo Yoga 710-14IKB Speaker Replacement
Wat je nodig hebt
  1. Lenovo Yoga 710-14IKB Speaker Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Speaker Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 710-14IKB Speaker Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 710-14IKB Speaker Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Speaker Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Speaker Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Speaker Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Speaker Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Speaker Replacement, Speaker: stap 6, afbeelding 1 van 1
    • Locate the speaker's plug and disconnect it.
    • Follow the wires connected to the plug to locate the speakers. The left speaker will have red wires, and the right speaker will have blue wires.
  7. Lenovo Yoga 710-14IKB Speaker Replacement: stap 7, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Speaker Replacement: stap 7, afbeelding 2 van 2
    • Untangle the wires from the plastic hinges of the case to properly lift the speakers out.
Conclusie
Bailey Murphy
85 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 9
Altijd: 741
