Ga door naar hoofdinhoud
Lenovo Yoga 710-14IKB Motherboard Replacement
Wat je nodig hebt
  1. Lenovo Yoga 710-14IKB Motherboard Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Motherboard Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 710-14IKB Motherboard Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 710-14IKB Motherboard Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Motherboard Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Motherboard Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Motherboard Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Motherboard Replacement, SSD: stap 6, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Motherboard Replacement, SSD: stap 6, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the 3mm screw on the SSD.
  7. Lenovo Yoga 710-14IKB Motherboard Replacement: stap 7, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Motherboard Replacement: stap 7, afbeelding 2 van 2
    • Use your fingers to lift up the SSD and pull away from the socket removing it from the laptop.
  8. Lenovo Yoga 710-14IKB Motherboard Replacement, Motherboard: stap 8, afbeelding 1 van 1
    • Use a PH00 screwdriver to remove the nine 3mm screws.
  9. Lenovo Yoga 710-14IKB Motherboard Replacement: stap 9, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Disconnect the indicated cables from the motherboard.
    • Be careful when removing cables. Do not pull or yank cables from their slots.
    • Remove the motherboard.
    • If you want to fully remove the motherboard, you must desolder the display cable.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Evan Cruzen
253 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 2,884
