Ga door naar hoofdinhoud
Lenovo Yoga 710-14IKB Headphone Jack Replacement
Wat je nodig hebt
  1. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Ensure your device is completely OFF before starting this guide.
    • Use a Torx T4 screwdriver to unscrew the nine 5 mm screws holding the cover in place.
    • Use a Torx T4 screwdriver to unscrew the 8 mm screw in the center.
    • When, reassembling, make sure not to tighten the screws too much or you may risk cracking the plastic cover.
  2. Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 2, afbeelding 1 van 3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 2, afbeelding 2 van 3 Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 2, afbeelding 3 van 3
    • Use the plastic opening tool to pry the cover up and away from the laptop, starting at one end and working your way around the cover.
    • The cover is large and flat and made of thin plastic. It cracks easily, so make sure not to pry too hard.
  3. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: stap 3, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement, Battery: stap 3, afbeelding 2 van 2
    • Use a Phillips #00 screwdriver to remove the four 3 mm screws holding the battery in place.
    • Be careful not to cross-thread the screws. Also, don't let the screws fall down into the laptop case.
  4. Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 4, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 4, afbeelding 2 van 2
    • Use your fingers or an opening tool to slide the battery connector out of its motherboard socket.
  5. Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 5, afbeelding 1 van 1
    • Remove the battery.
  6. Lenovo Yoga 710-14IKB Headphone Jack Replacement, Headphone Jack: stap 6, afbeelding 1 van 1
    • Remove the two 3mm screws from the headphone jack using a PH00 screwdriver.
    • Make sure not to strip the screws as they can sometimes be hard to remove.
  7. Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 7, afbeelding 1 van 1
    • Pop the black bar on the tip of the wire connected to the headphone jack circuitboard.
    • Disconnect the wire.
    • Be careful not to pull or yank the cable.
  8. Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 8, afbeelding 1 van 2 Lenovo Yoga 710-14IKB Headphone Jack Replacement: stap 8, afbeelding 2 van 2
    • Remove the headphone jack circuitboard.
Conclusie
Evan Cruzen
253 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018 Lid van UMass Dartmouth, Team S5-G8, Gulbrandsen Fall 2018
UMASSD-GULBRANDSEN-F18S5G8
3 Leden
9 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 583
