Ga door naar hoofdinhoud
Lenovo Yoga 710-11ISK Speaker Replacement
Wat je nodig hebt
  1. Lenovo Yoga 710-11ISK Speaker Replacement, Speaker: stap 1, afbeelding 1 van 1
    • Remove the 11 screws located on the back panel using a T5 Torx screwdriver.
  2. Lenovo Yoga 710-11ISK Speaker Replacement: stap 2, afbeelding 1 van 1
    • Insert an opening tool between the bottom panel and chassis, then pry around the entire perimeter until the five clips detach, releasing the bottom panel.
  3. Lenovo Yoga 710-11ISK Speaker Replacement: stap 3, afbeelding 1 van 2 Lenovo Yoga 710-11ISK Speaker Replacement: stap 3, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the four screws securing the battery.
    • Grip the battery cable connector on both sides of the plug and gently pull it directly from its port.
    • Lift the battery up and out.
  4. Lenovo Yoga 710-11ISK Speaker Replacement: stap 4, afbeelding 1 van 1
    • Unplug the wire harness on the left side of the computer to disconnect the speakers from the motherboard
    • Remove the white and blue wires from the plastic brackets holding them in place.
  5. Lenovo Yoga 710-11ISK Speaker Replacement: stap 5, afbeelding 1 van 3 Lenovo Yoga 710-11ISK Speaker Replacement: stap 5, afbeelding 2 van 3 Lenovo Yoga 710-11ISK Speaker Replacement: stap 5, afbeelding 3 van 3
    • Carefully remove both speakers and rubber grommets from their mounts.
    • Slide the right speaker underneath the white ribbon wire.
    • Lift the speakers up and out.
Conclusie
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 81
